help gen 1 swap
Old Feb 6, 2008 | 10:24 AM
blue_knight8's Avatar
blue_knight8
Default help gen 1 swap
hey can someone tell me how any mile neons die at ? im about to buy a motor that has 95 k on it is that to much for a neon ?
Old Feb 6, 2008 | 02:27 PM
12 volt's Avatar
12 volt
Default RE: help gen 1 swap
Mileage is not an indication of engine condition. Some low mileage vehicles are technically worn badly. Stop Start motoring, lack of oil changes or bad manufacturing causes this. Some very high mileage cars and bikes that have spent their lives on motorways and serviced regularly are found to be almost as new when stripped down. Worn engines may be a problem, high mileage may well not be. If you are unsure have a Garage compression test, and oil pressure test it and get the Mechanics opinion of its condition.
Old Feb 6, 2008 | 04:29 PM
tranyinstaller's Avatar
tranyinstaller
also a good idea to take off the valve cover and check for cam wear.
