Modded Intake Manifold Question...
Old Feb 7, 2008 | 02:28 AM
Slashwannabe's Avatar
Slashwannabe
Default Modded Intake Manifold Question...
Ok whats the RPM Range and HPbennifit of this intake if any at all?
Old Feb 7, 2008 | 11:51 AM
rayraydoet's Avatar
rayraydoet
Default RE: Modded Intake Manifold Question...
lol did you make that? maybe if u put a 4 inch instead of that 2.5 inch pipe you would have gained. and if u opened the ports up
Old Feb 7, 2008 | 02:23 PM
Slashwannabe
ORIGINAL: rayraydoet
Nope I didn't make it I was thinking about making it thats why I made the thread and asked first before I made a mistake . Not only that my Neon is Black and doesnt have a green Engine bay.
Old Feb 7, 2008 | 02:35 PM
tranyinstaller's Avatar
tranyinstaller
i see 2big advantages coming from this.
1) you can tune how long you want ur intake runners to be (shorter runners better for higher rpm and vice verce)
2) you can put any throttle body on you want so long as you can convert any and all necessary sensors.
oh and 1 last good thing is that you can get rid of a very anoying 90 deg. bend (after the throttle body befor the plenum).
oh and of course you could also choose for yourself how big (how much volume) your plenum will have.
Old Feb 7, 2008 | 03:48 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Thats 3 inch pipe, there is no 2.5 inch pvc...
Old Feb 7, 2008 | 03:52 PM
rayraydoet's Avatar
rayraydoet
sure there is they make pvc from 3/8s of inch to 10 inch
Old Feb 7, 2008 | 03:56 PM
rayraydoet's Avatar
rayraydoet
where did u get the picture? u got one of the thottle body? i want to see how he mounted and if its a stock throttle body. hey it cant hurt to experiment with a cheap investment. because you always can find a new plastic one dirt cheap if not and alumium one that u can make a custom intake. the onli thing i would have done differnt is i would make a venturi affect with the piece going to the throttle body so it was tapered for better flow
Old Feb 7, 2008 | 04:08 PM
Jr. Mechanic
You might possibly be able to get 2.5" pvc, buy you cant get it from a hardware store like lowes or home depot...
Old Feb 7, 2008 | 07:06 PM
95to96transplantneon's Avatar
that is off jeff b's sohc... one of very few 200hp NA sohc neons.
And this intake was on his car when the 206hp was dyno'ed... heres some more pics... oh and it was made out of 3 inch pvc...
[IMG]local://upfiles/61619/356D81D8F2A74A379B7241105B78069F.jpg[/IMG]
[IMG]local://upfiles/61619/44755C85280A4A738BD5A1C4BCC39730.jpg[/IMG]
[IMG]local://upfiles/61619/CC4B817ACA134AB6846C8B73EA44511A.jpg[/IMG]
[IMG]local://upfiles/61619/21A85BE6B3EE4145906C07B1EC1D89D0.jpg[/IMG]
[IMG]local://upfiles/61619/37B72FA7F81E482D9E8B13F76AB19EB1.jpg[/IMG]
Old Feb 7, 2008 | 08:12 PM
neonracer1010's Avatar
neonracer1010
just do this to instead will work just as good
http://www.audiforums.com/m_693578/mpage_1/key_/tm.htm
j/k
*im pretty sure ud get pretty decent gains out of it the air would have less distance and curves to go threw in order to get into the engine
