IM JINX i just change the oil
Old Feb 17, 2008 | 01:12 AM
dirt_trac_racer_80jr's Avatar
Default RE: IM JINX i just change the oil
ya id also like to know wat is funny ...
i thot i read something awhile ago simular to this ....i didnt think u could change your engine from dyno oil to synthetic oil ..i mena i kno u can ..but i thot it created problems ....any truth??
Old Feb 17, 2008 | 01:15 AM
jfink's Avatar
jfink
i switched after replacing the head and no problem. actually had an oil leak before and it stopped afterwards but i must have fixed it without knowing what it was. so now my brothers 2001 chevy s10 leaks and my 95 leaves the driveway clean
Old Feb 17, 2008 | 02:45 AM
12 volt's Avatar
12 volt
ORIGINAL: dirt_trac_racer_80jr
from mobil 1 .com
Question:
Switching From Conventional Motor Oil to Mobil 1
There seems to be confusion about how to make the switch from conventional motor to synthetic. I am a do-it-yourselfer. Could you provide instructions?
--Joe D.,Miami,FL
Answer:
The instructions are very easy to follow: Simply change the oil as you would normally. Any “confusion†is just myth. You can switch from conventional motor oil to Mobil 1 synthetic (and back again, if you want), without following any special procedures. The only exception to this is with a higher-mileage engine that has never used synthetic motor oil, or with an engine that has used conventional motor oil and been poorly maintained. In these cases, you should still follow the same basic oil-change procedures (drain the old oil, remove the old oil filter, put in new Mobil 1 and put on a new oil filter), but you should follow a regimen of one or two shortened oil-change intervals. For instance, let’s say that your regular oil change interval is 5,000 miles. If you’re switching to Mobil 1 under the circumstances mentioned above, make your next Mobil 1 oil change in 2,500 miles, your third Mobil 1 oil change 3,500 miles after that, and then follow your normal 5,000 mile oil-change interval. The reasoning behind this staggered interval is that a high-mileage engine, or one that has seen infrequent oil changes, will likely have a considerable build-up of sludge and deposits. Mobil 1 will help clean the engine as you drive, but it will have to work much harder in a very “dirty†engine, and so it is best to change the oil more frequently for those first few thousand miles. After that, you can rest assured that Mobil 1 is continuing to keep your engine running clean and well lubricated for mile after mile.
whats the right oil for my car?
http://www.mobiloil.com/USA-English/....aspx?option=2
Old Feb 18, 2008 | 11:14 AM
jdlee's Avatar
jdlee
Junior Member
ORIGINAL: jfink
ok...so you use to use 10w30.......then you changed the headgasket..........switched to 5w30 synthetic right? so now the oil light comes on(in the morning)?
Exactly, so what could be the problem or its just that my engine its damage by use (98,000 miles ) and now needs a ticker oil, and if thats the case whats the most ticker oil that i could use ( Dohc 99 ).
Thanks.
Old Feb 18, 2008 | 05:11 PM
12 volt's Avatar
12 volt
ORIGINAL: jdlee
ORIGINAL: jfink
Thanks.
you what to have the thinest oil possible that will stay in place and maintain a reasonable flim strength
use this link to find the best viscosity for you application
