crankshaft sensor
Old Feb 21, 2008 | 02:41 PM
tranyinstaller's Avatar
tranyinstaller
Default RE: crankshaft sensor
their probably telling him they have to drop the pan to get the sensor out because he's broke off most of it and there isnt much to get ahold on. if you go in, from inside ofthe pan, you can crank the engine over until the sensor and the pickup are close to each other and use a screw driver to pry the sensor out, from the inside. actually makes sence if he's thrashed the sensor bad enough.
So far as dodge being the only one you know of using a crank sensor. your smoking crack. maybe other companies dont use a crank sensor in paticular. however what you really need to think about is, why. dodge uses a crank sensor and a cam sensor to judge timing. since the timing on these cars are distributor-less they have to have a sensor to determan when to spark. so instead of just using a cam sensor and risking bent valves in the off-chance that a stupid sensor goes out, they use 2 sensors. that way if one goes out youve got a backup, and having a backup means not having a blown up engine. im all for the crank sensor. im sorry your having problems with it, but it serves a good purpose and im happy its there.
Old Feb 21, 2008 | 03:12 PM
12 volt's Avatar
12 volt
risking bent valvesin the off-chance that a stupid sensor goes out
i agree with you comment but not the part about the bent valves
Old Feb 21, 2008 | 08:12 PM
tranyinstaller
yah i was thinking about that later, and i was totaly off on that. sorry its been a VERY long day [&:]
Old Feb 21, 2008 | 11:34 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Well mine when out in my 96 neon and i got it off no problem. You work in a shop and never change one? I find that hard to believe. I knew about them way before mine went out. And i am not a mechanic.
