Crazy neon
Old Feb 21, 2008 | 06:18 PM
chilliewillie812's Avatar
chilliewillie812
Default Crazy neon
Ok this thing is still crazy at 4200 rpm fuel pressure is at 49 the TPI is ok I cheked by the ohm meterand it tested good. The cam senor is new and the MAP is new. Oh I cheked the resistance in the injectersand all cheked out good. But my car is still not right I cheked the coil pack and it read the right ohm's on the top post. But on the pins it read 1.2 ohm's and the book said it should be.45 to .65
does anybody have a good coil pack thay could chek and see what the good coil pack reads and let me know. Its for a dohc 2.0 97 model or do y'all know of somthing else it could be oh I got a new pcm to from modronperformance this thing is crazyholler back THANKS
Old Feb 22, 2008 | 07:42 AM
chilliewillie812
Default RE: Crazy neon
OK some body has a old but good coil pack thay can chek and give me the readings. lol
Old Feb 22, 2008 | 12:16 PM
12 volt's Avatar
12 volt
i have not idea what the ohms should be, but im going to go out on a limb and say this problem kinda sounds like O2 sensor
Old Feb 22, 2008 | 04:39 PM
12 volt's Avatar
12 volt
look what i found..........coil test porcedure
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Feb 22, 2008 | 05:49 PM
chilliewillie812
Hay thanks I realy think my coil pack is bad it reads 1.2 on the bottom pins so i got a msd coming it should be here next week. The book said the same thing .45 to .65 . Think of anything else let me know. THANK YOU MAN AM CRAZY FOR NEONS!!!
