Ground cable reading 12.45v??
Old Feb 23, 2008 | 07:03 PM
Dagenhamgeoff's Avatar
Dagenhamgeoff
Default Ground cable reading 12.45v??
Hi again people, just a uick and probably dumb question but here goes.....car will not start, it has done recently but now nothing......tested battery which was new, 12.45v....then I went to test the grounds.....had negative probe attached to negative terminal of battery and then glanced at the voltometer.it was reading 12.45, the other probe was resting on the engine block........now the really dumb uestion is......is it normal to have 12 volts running from the negative terminal of the battery and the engine block.i kinda think not but I`ve no idea about electrics...........friend said I`ve a short somewhere.....is he correct and if so where would be the best place to start looking, I really have had nothing but trouble with the car since August and I`ve not even driven it out of town yet....any help would be truly appreciated
Geoff
Old Feb 23, 2008 | 07:32 PM
12 volt's Avatar
12 volt
Default RE: Ground cable reading 12.45v??
smothing like this
no you shouldnt have power when you do that. if you do it could be a short but if it was your batt wouldnt last long
Old Feb 24, 2008 | 03:50 AM
Dagenhamgeoff
12 volt you`re the man, guess thats what killed the last battery lol now it`s wire tracing time.jeez where do i start lol.......thanks again 12
Old Feb 24, 2008 | 02:35 PM
12 volt's Avatar
12 volt
i would suspect that if your getting 12.45v at the engine (really strong short) the first place i would look is the starter.
