Head gasket
Old Feb 25, 2008 | 06:55 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default Head gasket
Can i use 2 head gaskets or do the make thicker ones to lower my compression? Then use a sohc block with dohc head. Is it worth it? How much will it lower my compression?
Old Feb 25, 2008 | 09:09 PM
95to96transplantneon's Avatar
Default RE: Head gasket
you can but not advisable at all... you can get one that is thicker just for that purpose...
Old Feb 25, 2008 | 09:31 PM
Slashwannabe's Avatar
Slashwannabe
If you use the SOHC bottom end with the DOHC head you'll have 9.4-1 compression which is almost ideal for turbo charging. The DOHC bottom end has flat toppistons and the sohc has a small dish which would work better to get your compression down. I say the DOHC head on the SOHC bottom end alone is enough of a drop in compression.
Old Feb 26, 2008 | 10:56 AM
I_Ride_Neon
So should i not use a thicker head gasket? I only plan on running around 10 pounds of poost. But i was to be safe not sorry. Where would i find a quality thick headgasket
Old Feb 26, 2008 | 12:35 PM
das2123's Avatar
das2123
DOHC pistons are domed to increase compression.
Just use a quality HG!
