tranfer gear
Old Feb 26, 2008 | 03:16 AM
rayraydoet's Avatar
rayraydoet
Default tranfer gear
the 1.22 gear what car and year can i get it out of? some one hewlp me ? tomarow im overhauling my tranny
Old Feb 26, 2008 | 07:24 AM
rayraydoet's Avatar
rayraydoet
Default RE: tranfer gear
an whats up with this forum i come for help and even a moderator cant anser me thanks for the help people. maybe some one on neonsDOTorg will actualy anser all my posts....l[:@] and this message is for every post that people dont bother to help a brotha out. i thought forum is for people to talk about car stuff ovously people dnt care to help, only them selfs
Old Feb 26, 2008 | 12:55 PM
das2123's Avatar
das2123
Man, calm down. You asked the question this morning and some people may not know the answer. Ask on the org and you will be told to use the "search" button more than likely.
ORIGINAL: Mookie
To find transfer gears, you need to look in 1978 through 1980 L-Body cars. these were the Omni, Horizion, Charger, and Turismo. look in the cars with the 1.7L VW engine, and the auto trans. you can also find these gears in some early 80's carburated Minivans. the top gear has 49 teeth, while the bottom gear has 60 teeth. to remove the gears, simply pull the drivers wheel off, remove the acess panel, and expose the gears. now with a 32mm socket and a breaker bar with a pipe on it (the bolts are torqued down to 200ft/lbs) remove the nuts. then use a regular power steering wheel puller to remove the gears. they should come off easily.
Old Feb 27, 2008 | 08:55 AM
HarleyRider68's Avatar
HarleyRider68
I got mine at a local tranny shop for $30.It only took about 1/2 hour to install. Pretty muchall Chrysler 3 speed trannys from the 80's and 90's used the same gears.
Old Feb 28, 2008 | 05:11 PM
rayraydoet's Avatar
rayraydoet
i found a trans but the engine was a 2.2 will it still work???
Old Feb 28, 2008 | 05:37 PM
95to96transplantneon's Avatar
ORIGINAL: rayraydoet
dude seriously, I'm not trying to be a dick but we have helped you myself included with just about everything you have ever asked us... and I have acually done research on things for you that I dident know just to give you an answer...
As far as the gears go harley gave you an answer... Call to a transmission shop and say " hey can you get me a 1.22 gear from a 80's to 90's chrysler 3 speed tranny" and there you go... but yes the 2.2 used the same gear... why buy used if you can get new for 30 bucks...
Old Feb 28, 2008 | 08:48 PM
rayraydoet's Avatar
rayraydoet
i never said you didnt help me but i got mad posts that people have never ansered me and the only way to get any one to anser is to say im pissed and thanks u ansered a nother question i didnt ask that you can " buy it new"
no 1 said that
