UDP
Old Feb 27, 2008 | 02:42 AM
ryleynoyes's Avatar
ryleynoyes
Default UDP
I'm looking at buying the MPx underdrive pulley, which not only is the pulley, but also new belts. the problem is, i'm taking out my A/C, so i will need a shorter belt on that side. anyone know what length belt i would need? also, any recommended brands?
i looked up the belt number that MP gives for its included belt vs. stock, and that seems to be about 2 inches shorter effective length, and stock w/o a/c is 41 or 42
anyone have any part numbers to look up?
thanks!
Old Feb 27, 2008 | 02:20 PM
95to96transplantneon's Avatar
Default RE: UDP
I run that same setup... give me awile to go out and find the belt number... im sicker then **** today and will make it out there when i can
Old Feb 27, 2008 | 02:45 PM
das2123's Avatar
das2123
Default RE: UDP
I am real tempted to yank the AC and P/S stuff out of my ACR to free up some room, but can't do it just yet.
Old Feb 27, 2008 | 03:17 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: UDP
Cant you just order the UDP that is specifically for neons w/out AC?
Old Feb 27, 2008 | 03:24 PM
das2123's Avatar
das2123
Default RE: UDP
The Unorthodox pulley I think has one for street and race.
Old Feb 27, 2008 | 03:58 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: UDP
if you yank out the P/S ande AC you wont need a belt at all
Old Feb 28, 2008 | 12:20 AM
ryleynoyes's Avatar
ryleynoyes
Default RE: UDP
for now, i like PS!
and i don't want to spend double on the Unorthadox, and the MPx one didn't have the option for ps only, that i saw
Old Feb 28, 2008 | 03:27 AM
dirt_trac_racer_80jr's Avatar
Default RE: UDP
www.andysautosport.com
this site has a udp that i bought for my neon ...im very happy with it ..its the megan racing...relativly cheap to ...i payd 80 something after shipping
Old Feb 28, 2008 | 03:33 AM
Default RE: UDP
o sry ..i alomst forgot ur other Q'...there is a formula for figuring out wat size of belt ull need ..i can get it for u if u like ...its wriiten down in my notebook in the garage ...but the easiest way to go is to take a piece of string and wrap it around the pulleys just like the belt would run after the pulleys are installed...cut it to size and messure it ....take the string with you when u go to buy ur belt or belts and the guy behind the parts counter should b able to fix ya up ..if he has any idea wat hes doin ..haha
