Crashed, fonr bumper bent down and hood buckled. help replacing.
Old Feb 27, 2008 | 01:52 PM
jmrmotorhead's Avatar
jmrmotorhead
Default Crashed, fonr bumper bent down and hood buckled. help replacing.
I drive a 1995 neon sport. Long story short i was following a freind the other day, and the car infront of herstoped short. I was on ice, and slide 20 feet into her cavalier. The only damage i can see is the hood is in definate need of replacement, fog lights were cracked and the bumer is bent down. i think this is becasue the reinforcement was bent in the accident. how is that metal reinforcement attached to the car? i havent taken the bumper off yet, as it is still drivable as is. i found the parts relitively cheap, but im not sure exactly how to go about replaceing the bumper. and info or tips would be apreiciated,
thanks,
Matt
Old Feb 28, 2008 | 03:42 AM
dirt_trac_racer_80jr's Avatar
Default RE: Crashed, fonr bumper bent down and hood buckled. help replacing.
the front bumper doesnt have any steel reenforcements ....the bumper cover bolts on the sides and underneith...then theres a piece of styro-foam that is molded to the bumper and bumper cover ...after the foam is the actual bumper which is bolted to the unibody or subframe which ever u call it ...my gess the that the actual bumper got bent at the bolts...i wouldnt wry to much about changin it ..its a pretty simple repair...you might actually be able to bend it back into shape and get away with buying a new one...a pic of the front of ur car would help alot...
Old Feb 28, 2008 | 04:43 PM
jmrmotorhead
Allright, so i pulled off the bumper to see what kind of damage was underneath... and i found that the actual bumperr seems to be definatly deformed. It is bent down, and i wasnt able to straighten it up. Where would you recomend getting the parts from. I would like to put a body kit on and maybe a non-stock hood. but i dont want to speand lots of extra mmoney. Any sugestions would be great.
matt
Ill get you a picture soon
