DOHC to SOHC Alt. Swap. Possible?
Old Feb 28, 2008 | 12:20 PM
2neonguy's Avatar
2neonguy
Default DOHC to SOHC Alt. Swap. Possible?
I've got a '97 DOHC and a '97 SOHC. Since they both need new alternators..
1: I am assuming the Neon Alternators can be rebuilt for cheaper than buying new. Is this correct???
2: Since I don't want to take my DOHC out of service, can I pull my SOHC Alt., have it rebuilt and swap it into the DOHC and vise versa??
Thanks!!
Old Feb 28, 2008 | 12:28 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: DOHC to SOHC Alt. Swap. Possible?
Ok, well first off, why don't you just fix the alternators for the cars, instead of swapping them?
New alternators are not that expensive and rebuilding them can be a pain if you aren't experienced.
Old Feb 28, 2008 | 01:54 PM
95to96transplantneon's Avatar
but yes the alternators are the same...
Old Mar 3, 2008 | 12:08 PM
2neonguy's Avatar
2neonguy
Thanks for the info!!
Old Mar 3, 2008 | 04:18 PM
Slashwannabe's Avatar
Slashwannabe
Same Block and mounting hardware for the SOHC and DOHC plus they run the same accessories in the same car, no reason they would be different.
