should i buy this header
Old Mar 1, 2008 | 12:06 AM
justinsanders's Avatar
justinsanders
Default should i buy this header
it deletes my cat but dont know if i should go 4 it cuz if i decide to put a cat on it i cant put one on b4 the downstream o2 sensor http://cgi.ebay.com/ebaymotors/OBX-E...spagenameZWDVW
Old Mar 1, 2008 | 12:16 AM
justinsanders
Default RE: should i buy this header
any one?
Old Mar 1, 2008 | 12:18 AM
unclemike's Avatar
unclemike
Where is it made?
If you have been following news reports of rat poison in pet food ingerdients, antifreeze in toothpaste and children's toys decorated with lead paint buying over seas made products is a crap shoot.
Old Mar 1, 2008 | 12:23 AM
justinsanders
dont kno but its gotta full warrenty
Old Mar 1, 2008 | 12:30 AM
unclemike's Avatar
unclemike
I suppose you could ask the seller where it's made and who honors the warranty. If it goes bad or is made wrong will he make it right or do you have to send it back to the factory?
Old Mar 1, 2008 | 12:55 AM
95to96transplantneon's Avatar
the merge collertor isent the best but you see an increase up top many people have scooped these up as a cheap alternitive, and they work pretty well... just the merge collector leaves a bit to be desiered...
Old Mar 1, 2008 | 03:06 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Obx???
Old Mar 1, 2008 | 03:20 AM
obx is a knock off company but they are the best knockoff comany they acually make the parts by getting a good one in this case it was a Tti long tube, and make a jig around the tti and then take a bunch of messurments and make a knockoff... like i said before the merge collector is not as good meaning the time was not spent grinding down the inside welds where the 4 tubes meet in the merge collector....
obx makes really decent well made parts for lots of cars for a good price... there about 95% as good as the real thing... some of there stuff is 100% but its the simple stuff... pretty reley able... the only neon part they make you have to watch out for is ther lsd... you need to modify it first to make it work correctly if you install it the way you get it... your passenger side axel will get stuck in the transmission never to come out again... without taking the whole transmission apart. but there are how to's to fix the obx lsd, after that it works just as well as the qualife but for half the price...
Old Mar 1, 2008 | 09:59 AM
Jr. Mechanic's Avatar
Jr. Mechanic
You can get a kirk racing header from modern for about the same price...
Old Mar 1, 2008 | 01:41 PM
or a used kirk for 150 if you know where to look... and its not a once and a while thing...
