Intermittent Wipers not working
Old Mar 1, 2008 | 01:09 PM
PurSid's Avatar
PurSid
Default Intermittent Wipers not working
I have a '95 Neon Highline and the intermittent wipers do not work. If I put the wiper switch up one position, where the intermittent should work, the wipers run at low speed, and they stop on the windshield where ever I put the wiper switch back to off. I replaced the wiper switch with one I have out of my '99 Neon sport, but it operates the same way.
My quesiton:
Where is the intermittent wiper control module located on a '95 Neon Highline?
Thanks -
Old Mar 2, 2008 | 09:13 AM
PurSid's Avatar
PurSid
Default RE: Intermittent Wipers not working
Could it be that the motor for the wipers is the issue?
I may just replace the motor assembly seeing as the more I think about what is wrong with it, the more I think it has something to do with the motor assembly.
Old Mar 2, 2008 | 05:02 PM
dcmcguy's Avatar
dcmcguy
the intermittent wipers are just opperated with different resistors inside the wiper switch. i'm pretty sure there is no intermitent wiper module. I would just replace the motor since the motor has a couple different sets of brushes in it, and they might be acting dumb...lol.
Old Mar 4, 2008 | 11:13 AM
PurSid's Avatar
PurSid
Yep that was it.
Swapped out the wiper motor from a '99 on to my '95, had to change the wire harness plug, all together took 30 minutes, and now the wipers work as they should.
