CEL code 52 12 and 25
Old Mar 5, 2008 | 04:30 PM
lateralus823's Avatar
lateralus823
Default CEL code 52 12 and 25
Okay i need some serious help i have like 4 days to get my car inspected, i cannot for the life of me keep the cel off. Itll stay off for a bit then it comes on. In new york u can have 2 monitors that dont pass, well everytime i get to 2 the cel goes off i dont understand it.
I have a punched out cat and no a/c not sure if itd **** with it but one thats not clearing is the evap. i think it may be throwing them codes? im not all to sure but a few days ago my uncle cleaned the iac and im not all to sure if it helped or not but i need some suggetsions asap please, spud? das? thanks
Old Mar 7, 2008 | 03:56 AM
pimpberetta's Avatar
pimpberetta
Default RE: CEL code 52 12 and 25
25 Idle air control motor circuitstarget idle not reached (+/- 200),vacuum leak found
52 Fuel system rich
At least its not lean lol
I would look at all your vacuum lines first off and make sure there nice and snug. You could even clamp them to be extra sure, but the hoses are usually pretty tight on the fittings anyways. Check that first and tell us what you find.
I don't recall what you can spray on the lines to see if there leaking, I believe its propane or something similar. And it will increase your rpm's from an idol stand point if it is infact leaking.
Be careful,
Sean
Old Mar 7, 2008 | 04:48 AM
95to96transplantneon's Avatar
I would seriously think about going down to the parts store with everysingle vac line that in your motor and spend the 20 bucks to compleatly re-line your car... for 20 bucks I would do it...
your probally running rich due to the vac. leak thats causing the iac sensor to read more air so more fuel... hence the rich condition... is your tb plate sitting flush and compleatly close???
Is your tb compleatly tight with the gasket... how about your intake manifold gasket???
Old Mar 7, 2008 | 06:03 AM
lateralus823
how do i know which vac lines to buy?
