fuel pump question
Old Mar 6, 2008 | 12:18 PM
spp's Avatar
spp
Default fuel pump question
ok i got 97 neon shoc. i have a problem wit my fuel pump fuse it keep blowin. so i think i got a short in my wires.. someone please tell me how to fix it.... i just added up my money on the fuses i brought it came up to 100.00.... so someone please give me some pointers
Old Mar 6, 2008 | 02:43 PM
johnneon's Avatar
johnneon
Default RE: fuel pump question
did you check yourdownstream oxygen sensor cause if your 02 sensor wire is broke and touches your exhaust it will blow your fuel pump fuse...
Old Mar 6, 2008 | 02:47 PM
12 volt's Avatar
12 volt
well i guess you have traced all the wires back to the pump.have you checked inside the tank?
if it was me i would just run new wires
Old Mar 7, 2008 | 12:20 PM
spp's Avatar
spp
how much is it to change the wires and the o2 sensor
Old Mar 7, 2008 | 02:08 PM
12 volt's Avatar
12 volt
wire is pretty cheap, o2 senoris like $50.
Old Mar 7, 2008 | 09:35 PM
spp's Avatar
spp
where to get the wires from
Old Mar 7, 2008 | 10:02 PM
12 volt's Avatar
12 volt
parts store or home depo, i think its like 18 gauge or something.
