WTB lots o parts...
Old Mar 11, 2008 | 11:19 PM
ryleynoyes's Avatar
ryleynoyes
Default RE: WTB lots o parts...
well, i have a vibration at about 60+ mph, but i know for sure it's not a misbalanced tire
i also think i might have an exhaust leak, but i'll be changing the exhaust manifold soon anyway when i put the turbo on
Old Mar 13, 2008 | 02:49 PM
tranyinstaller's Avatar
tranyinstaller
if ur axles were going out you would get a really anoying "knock, knock, knock" whenever you turn the wheel and are moving. vibration could be as simple as a misballanced wheel or warped rotors. if you bring your car to a full stop turn the wheel all the way to either direction and start moving forward with med. to heavy throttle, do you get a knocking sound?
Old Mar 13, 2008 | 04:45 PM
ryleynoyes's Avatar
ryleynoyes
i suspect it's not something simply misbalanced, as it only vibrates (shakes, rather) under acceleration, even light, at speeds around 60+.
itsometimes shakes at slower speeds, but not all the time. it almost always does at the higher speeds
Old Apr 4, 2008 | 03:12 PM
ryleynoyes's Avatar
ryleynoyes
bump and update
i ordered the stage 3 axles, and a set of swaybars from modern, and ordered a rear swaybar adapter kit (as my car doesn't have a factory rear swaybar) from streetbeat (street beat or street beat customs, somethin like that). then they called me just today to say they can't get the swaybar adapters anymore
so i did some searching today, and i found this
http://www.autopartswarehouse.com/de...I20287005.html
which not only do i think it's bigger bars (if i'm remembering right, the suspension techniques is 22 front/19 rear, these are 24 front 21 rear, correct me if i'm wrong), but they also appear to come with the bracketing that i need, correct?
Old Apr 4, 2008 | 04:09 PM
12 volt's Avatar
12 volt
you still need the brakets that mount to the rear strut
http://www.neongoodies.com/Goodies/S...Hardware.shtml
Old Apr 4, 2008 | 05:18 PM
ryleynoyes's Avatar
ryleynoyes
ORIGINAL: 12 volt
i already ordered that exact kit from vitor, but i'm meaning the brackets under the car, near the gas tank on the frame rail things
the Suspension techniques adapter kit (number 55335) is discontinued, and no one has it in stock that i've found, they all just ordered directly from suspension techniques and had it shipped direct
