CODE P0420
Old Mar 9, 2008 | 09:17 AM
lateralus823's Avatar
lateralus823
Default CODE P0420
I have the code p0420 what is it? and could it cause me to run to rich?
Old Mar 9, 2008 | 12:22 PM
95to96transplantneon's Avatar
Default RE: CODE P0420
code 420 huh i think that means you car wants to get stoned...
but heres a free bump for your problem... lol
Old Mar 9, 2008 | 01:24 PM
12 volt's Avatar
12 volt
ORIGINAL: lateralus823
https://dodgeforum.com/m_614377/tm.htm
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
could be bad O2 sensor (will make you run rich) or cat converter or a reminder to blaze a fat one
Old Mar 9, 2008 | 01:53 PM
lateralus823
Well both 02s are brand new, and the cat is gutted
Old Mar 9, 2008 | 02:09 PM
neoncrazy101's Avatar
neoncrazy101
if the cat is gutted Bank 2 sensor could be messing up. Bank 1 is before the Cat. Bank 2 is after.
Old Mar 28, 2008 | 04:14 PM
Swanny's Avatar
Swanny
Gutted cat is the problem. More info on the code: http://www.obd-codes.com/p0420
Your options are live with the code, replace the cat, or put on a high-flow cat.
Old Mar 28, 2008 | 04:18 PM
Swanny's Avatar
Swanny
ORIGINAL: neoncrazy101
No, that's not correct. Banks 1 & 2 refer to which side of the engine (bank 1 is the side of the engine with cylinder #1). The sensor before the cat is Sensor #1 and the one behind is Sensor #2.
For example, you could have the same description for Bank 1, Sensor 1. Or it could be for Bank 1, Sensor 2. Or Bank 2, Sensor 1, etc.
A P0420 usually means the cat is bad. In this case that's a given. The code will not go away until the cat is replaced. Beware cheap, inferior cats that don't last!
