best place to drill threw firewall
when i ran my wires for the amps i just poked a hole thru the rubber grommet that the wiring harness comes out of.
how does the gauge sense pressure?
its mechanical and im just gonna put it where the stock temp sensor goes on the intake manifold. and then figure somthing out to do with the stock sensor, id put it threw the gromet but i only have like 6 feet of cable to work with.
You will need to find a better place to install your sensor. If you unplug the stock one, the PCM will not get a reading and it will run the motor realy rich. Been there done that.
ORIGINAL: dirtracer24
I can't nobody has mentioned the free and open gromet that is right next to brake cylinder, all you do is squeze yourself between your drivers seat and dash and look a little up past your brake pedal where it goes into the brake cylinder and you'll see a rubber gromet, just pop it out from the inside with your finger and you'll have a 2 inch wide circular hole to put your boost gauge tubing and boost controller vaccum hose through and whatever else through.
Trending Topics
ORIGINAL: Slashwannabe
Its a plugged hole all by itself nothing runs through it, its next to the harness gromet though I'll take a pic and show you and you can tell me if you ever seen it
answer this one somebody? wheres the best spot to put the temp gauge sensor? is there a plug in the back of the block somewhere? i think there mite be but im not sure if what i see is for water or oil pressure
