NEWBIE TO NEON
Old Mar 11, 2008 | 04:34 PM
mcss8541's Avatar
mcss8541
Default NEWBIE TO NEON
GREETINGS AND SALUTATIONS EVERYONE, I JUST BOUGHT A 1997 DODGE NEON 4-DR SEDAN 5-SPEED SOHC 2.0. SINCE I HAVE A DODGE RAM P/U I AM NORMALLY ON THE RAM POSTS BUT I WANTED TO GET ACQUAINTED WITH THE NEON SIDE AS WELL. IS THERE ANYTHING I SHOULD KNOW ABOUT THIS CAR? PERFORMANCE ADD-ONS! NOTORIOUS BREAKING STUFF? ETC. I JUST REPLACED THE CLUTCH AND BECAUSE MINE HAS THE LETTER "D" IN THE VIN IT HAD THE MOST EXPENSIVE CLUTCH KIT. IN DOING SO ALOT OF THE FLUID DRAINED OUT, WHAT WEIGHT GOES IN? THANKS!
Old Mar 11, 2008 | 04:55 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: NEWBIE TO NEON
5w-30 or 10w-30 will be fine. how many miles? and the pre-98 Neons are known for headgaskets. so check and see if it has the MLS gasket by looking under the intake manifold runners and seeing if u can see a flange of metal in between the head and block. if it is anywhere around 100k and/or you dont know if the timing belt and water pump were replaced, i would do that.
Old Mar 11, 2008 | 05:07 PM
12 volt's Avatar
12 volt
your talking MTX fluid right?
good reads for the first time neoner
https://dodgeforum.com/m_530310/tm.htm
https://dodgeforum.com/m_692727/tm.htm
https://dodgeforum.com/m_554034/tm.htm
Old Mar 11, 2008 | 05:48 PM
mcss8541's Avatar
mcss8541
YES I NEED THE WEIGHT OF THE MANUAL TRANSMSSION FLUID. I HAVE ALOT OF ROYAL PURPLE GEAR OIL BUT I NEED TO KNOW THE WEIGHT. IT HAS 117K MILES AND THE PREVIOUS OWNER STATED HE CHANGED THE TIMING BELT. WATER PUMP? I WILL CHECK THE HEAD GASKET BUT IN REPLACING THE CLUTCH I NOTICED THERE WAS AN OIL LEAK ON THE BACK SIDE OF THE MOTOR, IS THIS VALVE COVER RELATED OR THIS HEAD GASKET YOU MENTIONED? ALSO WHERE WOULD I GET A "MLS" HEAD GASKET? THANKS!
Old Mar 11, 2008 | 05:58 PM
neoncrazy101
MLS, autozone, modernperformance.com
the oil leaking could be the rear main seal. thats a common area for the Neons.
Old Mar 11, 2008 | 07:13 PM
95to96transplantneon's Avatar
they dont exactly make the "right" mtx oil any more... most of us just use atf+4 and change it about every 50k miles... works really well.. even in really cold weather...
Old Mar 11, 2008 | 07:49 PM
bone33's Avatar
bone33
ORIGINAL: 95to96transplantneon
i agree.
Old Mar 11, 2008 | 07:52 PM
neoncrazy101
the Pennzoil Syncromesh works good too.
Old Mar 12, 2008 | 11:45 AM
Spawne32's Avatar
Spawne32
Old Mar 13, 2008 | 04:43 PM
mcss8541's Avatar
mcss8541
ASK POLITELY AND I WILL SMART ***.
