Neon 96 TPS adjustment
Dear friends:
congratulations for your knowledge about Neons.
I am owner of Neon 1996, DOHC, the tps sensor are out adjustment,please help me todo the correct setting of Throttle position sensor and throttle stoping screw, i need correct values to performing these adjutsments.
Thank you
Thank you
the tps slides into a slot on the side of the throttle body when the butterfly is closed. Im not aware of an adjustment that can be made to the thing. a new one is like 67.99 from autozone if you think you need one. its just held in by two torx screws i think.
http://www.autozone.com/selectedZip,.../selectZip.htm
y is it such a big deal messin with that. if u go to low just go back a little bit. my neon idles at about 1500 rpms when its cold outside or when i push the clutch in and coastregaurdless of engine temp. but when its warm outside it will idle exactly at 1000 regaurdless of engine temp.
