Control Arm Bushings
Old Mar 12, 2008 | 08:18 PM
Spawne32's Avatar
Spawne32
Default Control Arm Bushings
Has anyone had any experience working on the suspension of these neons? I need new control arm bushings and im contemplating taking it to a shop or not.
Old Mar 13, 2008 | 12:02 AM
spudsterier's Avatar
spudsterier
Default RE: Control Arm Bushings
i installed the complete prothane suspension bushing kit on my car....putting in the new bushings was really easy, the problem was getting the old ones out
Old Mar 13, 2008 | 08:57 AM
Spawne32's Avatar
Spawne32
could you give me some details?
Old Mar 13, 2008 | 09:23 AM
spudsterier
well its fairly easyto remove the control arms, but once they are out, you will need to burn the old bushings out (causes alot of ash and smoke so dont do it around anything important). once the old ones are completely burnt out, press the new bushings in with a press or a vise.
then, to install the control arm back into the cross member, take a pry bar and pry the rear opening of the cross member when the control arm sits open a bit wider....then lube it up with some grease...then use a rubber mallet to beat the control arm back into its location...
sounds harder then it is
Old Mar 13, 2008 | 09:41 AM
Spawne32's Avatar
Spawne32
ill prolly wind up buying whole new control arms to make life easier :rofl:
Old Mar 13, 2008 | 04:57 PM
spudsterier
not like there is much of a price difference between new control arms and just the bushings....only like $300-$400
Old Mar 13, 2008 | 08:33 PM
Spawne32's Avatar
Spawne32
new control arm with bushings and a new ball joint is 180x2
Old Mar 13, 2008 | 10:56 PM
spudsterier
$360 compared to the $100 for the bushing kit....
though the bushing kit also gives you:
tie rod boots
front and rear sway bar bushings
front and rear sway bar end link bushings
front control arm bushings
rear trailing arm bushings
rear lateral support bushings
and i htink a few others...
notto mention it extremely increases your cornering and handleing abilities
Old Mar 13, 2008 | 11:02 PM
Spawne32's Avatar
Spawne32
took some pics on the passenger side today
Ball Joint
Sway bar link
tierod
