Crane12
Old Mar 15, 2008 | 09:17 PM
neoncrazy101's Avatar
neoncrazy101
Default Crane12
a guy from my work, has several SOHC's Neon parts. and one of which is a Crane 12 cam. he said he would give it to me for $100. my question is, i dont have any other mods to the motor itself yet. would it be worth it? and on a somewhat Neon would it gain any power? i know it will help when i start to mod it but will it on my Neon right now? and how hard is it to install a Cam? Also, could i still run 87Oct?
Old Mar 15, 2008 | 09:53 PM
95to96transplantneon's Avatar
Default RE: Crane12
you may want to jump on it... thats cheap... like cheap cheap... its not hard to swap them as long as the motor is out... but you can also just remove the bobble and fmm and passenger side mount and jack up the one side so you can get to the head... just make sure you use a new cam seal... you would get some gains but you will notice more of a gain every time you upgrade something the better the cam can breath in and out the more you will gain from not only the cam but the cai tb intake manifold head work exhaust manifold and exhuast piping...
Old Mar 15, 2008 | 09:58 PM
neoncrazy101
Default RE: Crane12
would i be able to run 87unleaded still though?
Old Mar 16, 2008 | 10:26 AM
spudsterier's Avatar
spudsterier
Default RE: Crane12
i run 87 every once and a while.....even with the mopar pcm and crane #14's....no problems yet[X(]
Old Mar 16, 2008 | 03:30 PM
neoncrazy101
Default RE: Crane12
ORIGINAL: 95to96transplantneon
wouldn't that damage the transmission?
ALSO sry, dont u have to take off the cam gear to take the cam out?
Old Mar 16, 2008 | 10:17 PM
jfink's Avatar
jfink
Default RE: Crane12
yes as for the transmission i've done it a few times and have no problems?
Old Mar 16, 2008 | 10:28 PM
spudsterier
Default RE: Crane12
it wont wurt the tranny because the mount has the rubber insert....allows everything to move about 3 inches in either direction...but that 3 inches makes a hell of a difference on jobs like this
