sway bar bushings
Old Mar 17, 2008 | 03:59 AM
12 volt's Avatar
12 volt
Default RE: sway bar bushings
ORIGINAL: Spawne32
what is an ACR and how do i find out if i have one, its a 1998 highline sedan
check you vin to comform what model you have.most likely a highline
"First-generation Neons were competitive in SCCA Solo autocross.[1] Available with both the SOHC (sedan) or DOHC (coupe) the ACR was competitive in its class, and featured four-wheel disc brakes, Arvin non-adjustable struts for 95-96 models and Koni adjustable dampers for 97-99 models, thicker anti-sway bars, fast-ratio steering, heavy-duty front wheel hubs, and a 5-speed manual transmission with a numerically higher .81 fifth gear and final drive ratio of 3.94 for quicker acceleration. 1995 through 1997 models featured adjustable camber. The computer-controlled speed limiter was removed from 1995 ACR models, and raised from the standard 190km/h (118mph) to 210km/h (130mph) for subsequent years. The ACR offers no badging to distinguish it from other Neon models; the only visible differences are a bumper with fog light holes, but no fog lights and a lack of side mouldings. In 1995, the ACR was only offered to SCCA members, but in subsequent years it was available to the general public. The name "ACR" was initially the internal ordering code for the "Competition Package", as it was termed in dealer materials; however, as knowledge of the model spread, the ACR name stuck, and backronyms such as "American Club Racer" were given to it by fans."
http://en.wikipedia.org/wiki/Dodge_Neon
Old Mar 17, 2008 | 10:56 AM
Spawne32's Avatar
Spawne32
VIN: 1B3ES47C5WD724874 Vehicle: 1998 DODGE NEON/HIGHLINE/SPORT/LE Records: 13 records found in the CARFAX Vehicle History database
Old Mar 17, 2008 | 07:45 PM
Spawne32's Avatar
Spawne32
any ideas?
Old Mar 17, 2008 | 07:55 PM
12 volt's Avatar
12 volt
Country : USA
Make : Dodge
Type : Passenger Car
Model Year : 1998
Safety System : Dual Air Bag; Active Restraints
Body : PL: Neon, Neon Sport
Series : Highline
Style : Style not in database!
Engine : Chrysler: 2.0L I-4 SOHC 132hp@6000rpm
Check Digit : 5
Plant : Belvedere, IL
Serial Number : 724874
http://www.allpar.com/mopar/vin-decoder.html
Old Mar 17, 2008 | 08:00 PM
Spawne32's Avatar
Spawne32
so....not an ACR? 20mm bushings?
Old Mar 17, 2008 | 08:07 PM
12 volt's Avatar
12 volt
ORIGINAL: Spawne32
correct your model is a highline
Old Mar 17, 2008 | 08:10 PM
Spawne32's Avatar
Spawne32
k thanks for the info
