OIL IN SPK PLUG HOLE
Old Mar 17, 2008 | 10:16 AM
mcss8541's Avatar
mcss8541
Default OIL IN SPK PLUG HOLE
Greetings, I am a new Neon owner (1997 Sedan 5-spd 2.0 SOHC) and I got a CEL with 2 codes. The 1st one I was aware of from the previous owner which is the EGR valve however the 2nd one was Culiner #1 misfore. Since I am familiar with these things I pulled the #1 Spk plug and when I got it out there was oil down in the "tube" that goes down into the manifold. Not alot and my oil level was normal and there was no oil on the area below the treads of the plug. Is this normal????? If not does it pose a potential problem or do I just leave it alone?
Old Mar 17, 2008 | 10:23 AM
neonracer1010's Avatar
neonracer1010
Default RE: OIL IN SPK PLUG HOLE
i think that that would probally be spark plug tube seals. im pretty sure it is but dont quote me on it
Old Mar 17, 2008 | 10:24 AM
spudsterier's Avatar
spudsterier
your problem is that one of your spark plug tube seals in bad...
just get a new valve cover gasket and it will come with them..
simple fix
Old Mar 17, 2008 | 10:29 AM
12 volt's Avatar
12 volt
could cause a misfire and foul up you wires.
Old Mar 17, 2008 | 11:10 AM
mcss8541's Avatar
mcss8541
Roger That My friend. Looks as though I have a project this weekend.
Old Mar 17, 2008 | 03:59 PM
snunicycler's Avatar
snunicycler
would this problem cause the car to die? i have same problem but my car wont run very long
Old Mar 17, 2008 | 05:59 PM
12 volt's Avatar
12 volt
ORIGINAL: snunicycler
misfires can make your car die, it depends on how badit isand how many cylinders
