Anyone need any parts?
#21
#22
#23
RE: Anyone one need any parts?
Shoot I'll take whatever you would recommend I'm a novice when it comes to Neons. Make a list and check it twice then come up with a price for the lot and shoot it to me. Also on a different note I want to run some 17" rims I saw on the Tirerack.com site, they recommend a 205/40/17 for that particular wheel is that the largest tire without rubbing? I thought I saw some guy on here saying to run a 215/40/17. Your views??????????
#24
Tires and related info
Q: What is the bolt pattern on the neon and offset?
A: Some early 95's have a 4x100, all other's have a 5x100 with a 40mm offset.
Q: Will the SRT fims fit on my 1st gen?
A: Yes they will, but the SRT's stock tires will rub. You will need to run 205/40-17's or 215/40-17's. The 215/40-17's will give you a bit of a rim guard against curbing due to a little overhang....the 205's have no overhang, they are flush with the edge of the rims. (Info courtesy of spudsterier)
Q: Will other neon rims fit on my 1st gen?
A: Yes, the 2nd gen and SRT rims will fit on the 1st gen.
Q: What size tire should I use if I am getting bigger rims?
A: 195/60-14, 205/60-14, 195/55-15, 205/50-15, 215/50-15, 205/45-16, 215/45-16, 205/40-17, 215/35-18 are some common tire sizes that will fit.
#25
#26
#28
Sorry got alot on my mind. I just found a neon for $200 only needs a windsheild. But if I buy it then I cant get my rims. Anyways. Then the 52mm tb will be an upgrade for the mtx. Throw me an offer for the stuff. I cant take pics if you want. The indiglo cluster has the 8k tack on it.
