2.4 swap
Old Mar 19, 2008 | 08:38 PM
krusher101's Avatar
krusher101
Default 2.4 swap
hey guys. I saw a 2.4 dodge motor in a dodge caravan today at the junkyard. Im not exactly sure of the year but it was about a 95. What all would i have to do to get it to bolt up into my neon that right now has a 2.0 sohc and a 5 speed transmission?
Old Mar 19, 2008 | 09:52 PM
95to96transplantneon's Avatar
Default RE: 2.4 swap
minimally...
1) 2.4L DOHC engine from 95-02 Chrysler Products
2) 2.0L DOHC Intake manifold AMM intake manifold...
3) 2.0L DOHC exhaust manifold (stock or aftermarket)
4) 2.0L DOHC Coolent hard pipes
5) 2.0L DOHC PCM (Stock, Mopar, or AFX)
6) 2.0L DOHC Wiring harness
7) 2.0L Crankshaft pulley (Some 2.4's will require the use of a 2.0L UDP)
8) 2.4L Motor mount adapter 70
9) PT Cruiser water pump output neck 4884291AA, O-Ring 6503180 2.63
10) 2nd Gen Neon fuel pressure regulator (58psi) OR 24lb. injectors (one or the other)
11) PT Cruiser alternator brackets
12) DOHC Hood
13) 2.4L Stratus motor mount
Old Mar 19, 2008 | 10:27 PM
krusher101's Avatar
krusher101
ok thanks! will it bolt up to my transmission?
Old Mar 19, 2008 | 10:58 PM
yes
any 1st gen transmission atx or mtx will bolt right up...
Old Mar 19, 2008 | 11:06 PM
krusher101's Avatar
krusher101
ok dude thanks alot!
