egr valve
Old Mar 21, 2008 | 06:18 PM
neonracer1010's Avatar
neonracer1010
Default RE: egr valve
can u take the sensor off the harness? the one that goes around the stock intake tube on a DOHC? i alredy have the egr blocked off but can i take that dumb sensor off?
Old Mar 23, 2008 | 06:30 PM
neonracer1010
bump
Old Mar 23, 2008 | 10:50 PM
dirt_trac_racer_80jr's Avatar
[sm=deadhorse.gif]..this question has been asked atleast 10 times since ive joined the forum
Old Mar 23, 2008 | 11:20 PM
95to96transplantneon's Avatar
it can be removed but it will pretty much throw a cel imideatly... unless you solder a resister in between the wires...
I want to say its a 22k ohm 1/4th watt resister... but dont quote me...
Old Mar 23, 2008 | 11:27 PM
neonracer1010
what bout the vaccum lines then that are on the thing
Old Mar 23, 2008 | 11:38 PM
if you taking about doing a block off... then you just take all of them off and one line should lead to the brake booster... just take the hose off and put a rubber nipple on there so you dont have a vac leak...
