dohc swap question
Old Mar 23, 2008 | 10:42 AM
pssssst's Avatar
pssssst
Default dohc swap question
okay so if i were to swap to a 2.4 or just the regular dohc 2.0 what would have to be done to my sohc wiring harness??? thanks guys!
Old Mar 23, 2008 | 06:34 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Default RE: dohc swap question
You will have to extend the wiring for the coolant sensor.
The cam sensor plug *may* have to be changed.
You will need to extend the wiring for the CPS if you go 2.4
The rest depends on the year of the engine in question. Mostly splicing connectors. I STRONGLY recommend getting a new harness at some point. Wiring issue can be never ending. Consider it.
