megasquirt
Old Mar 23, 2008 | 07:09 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Default megasquirt
Check this out. http://cgi.ebay.com/ebaymotors/Brand...em180226148437
If i get that will it elminate my ecu? Is there advantages for using it on a stock engine with boost? If i got it would I still need my missing link? Any other input?
Old Mar 23, 2008 | 07:19 PM
I_Ride_Neon
Default RE: megasquirt
Or what about a piggyback? http://cgi.ebay.com/ebaymotors/GRedd...spagenameZWD1V
Anyone know anything about that?
Old Mar 23, 2008 | 07:53 PM
95to96transplantneon's Avatar
e-manage has problems with the neon... few people run it... where as MS has a very wide base of support and it runs the neon very very well... better then the stock pcm could ever control it...
as long as the ms has spark and fuel you are able to remove the pcm but you have to do some more to get all the lights and what not that are not controlled by the pcm...
Old Mar 23, 2008 | 07:57 PM
I_Ride_Neon
Would I be better off getting the MS I, and keeping my stock computer in and use the MS?
Old Mar 23, 2008 | 08:25 PM
yeah you would be better just letting the computer deal with all that... and then use the ms to control everything motor related...
I would seriously concider spending the little extra money and getting the rsmotersports 420a ms it comes with a bunch of different maps to get you started... you just pick the one that is closest to your setup and load it... it will atleast get your car started, then you just tweek from there... otherwise you will have to build the maps up from scratch...
Old Mar 24, 2008 | 08:19 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
e-manage sucks *****.....used it once and NEVER will use it again!!!!!
