Information for a 2.0 engine swap - SOHC to DOHC
Old Mar 28, 2010 | 01:56 PM
  #31
mazdaracer's Avatar
mazdaracer
can anyone help me I have a few question on a motor swap problem
Old May 30, 2010 | 11:26 PM
  #32
randi69's Avatar
randi69
so if i want to take the SOHC motor out of my 1995 dodge neon and put it into the body of my 1998 DOHC dodge neon would it be worth it.
Old Jan 9, 2011 | 06:26 PM
  #33
VART's Avatar
VART
Default Head Swap
this might sounds crazy but has anyone even tried to swap a SOHC with a DOHC head? okay i know the piston will have to be change so why wouldn't work?
Old Jan 25, 2011 | 11:37 AM
  #34
advance's Avatar
advance
ijust did the sohc block from a 2001 acr and put my dohc head on it and so far so good ill let you know how it runs
Old Feb 9, 2011 | 09:23 PM
  #35
advance's Avatar
advance
i did it it runs like a top sohc block from a 2001 acr and a 1998 dohc head a little more compression but works well
Old Apr 18, 2011 | 11:08 PM
  #36
buddhaman's Avatar
buddhaman
is the DOHC rotating assmebly from a 1st gen work with a 2nd gen SOHC block? if not, can i use a 1st gen DOHC block with my 2nd gen SOHC head?
Old Aug 19, 2011 | 06:34 PM
  #37
dooley19's Avatar
dooley19
Default Plymouth Neon, Dodge Neon engine swap
I have a 1999 Plymouth Neon SOHC and I'm going to purchase a 1999 Dodge Neon DOHC. I was wondering will the motor from the DOHC Neon fit into my SOHC Neon. Would I need to change anything? The problem is the Plymouth Neon has a bad motor and the Dodge Neon has a bad transmission.
Old Jun 20, 2012 | 04:18 AM
  #38
kodahusky's Avatar
kodahusky
ok i have a 98 neon coupe that is the dohc w/manual tranny and the block and pistons need to be replaced. the head is still good along with all its valves. can i buy a sohc engine and swamp the heads on it because i already have all the parts i need?
Old Jul 22, 2012 | 02:05 AM
  #39
YourXdadsXstdz's Avatar
YourXdadsXstdz
Unhappy 2.4l head swap on dohc 2.0l block
hey guys i am new to this forum and am hoping you guys can help me with this project . so i have a 98 dohc neon fully built crane cams, and forged pistons with rods and so on.... so my head started to ticking noise bad and so i bought a 2.4l head with no more than 75,*** miles from a 99 stratus with the same matching cast #'s and am waiting to swap them out but i am not sure what i need in order to do the swap?? need some help. will the head be able to be interchanged or did i make a mistake in just buying the head? all i was able to find was the engine swap but nothing about the head swap on a 2.0l block ? well if you guys could help me i would appreciate it and would be extreamly helpful. thanx will post pictures up tommorrow
Old Nov 20, 2013 | 05:40 PM
  #40
vickie223's Avatar
vickie223
hey every one I jst did a 2.0 dohc engine swap for a sohc engine....will we need to swap THE BRAIN ECU ALSO?
