need help plz
Old Mar 28, 2008 | 02:32 PM
chenzo's Avatar
chenzo
Default RE: need help plz
Code 35- Radiator Fan Relay Circuit.
Let your car warm up to operating temperature, and check to see if the rad fans come on. If they don't then it could be your relay that's shot.
Old Mar 28, 2008 | 02:54 PM
95to96transplantneon's Avatar
the relay is under the drivers side headlight...
Old Mar 29, 2008 | 02:45 AM
firstgenneon's Avatar
firstgenneon
ok so my Code 43 Multiple/ single cylinder misfire could be the spark plugs or wires hopefully right?
Old Mar 29, 2008 | 03:26 AM
could be spark plugs wires or coil or wiring to coil...
Old Mar 29, 2008 | 10:31 AM
bone33's Avatar
bone33
ORIGINAL: 95to96transplantneon
here ya go... check out his store for cheaper alternitives...
but for 157 you can have a 1.24 - 8.95 mile radius depending on terrain... god i want one so bad...
http://cgi.ebay.com/Long-Range-Boost...742.m153.l1262
read the fine print, junior.
Transmission Range:
[ul][*][align=left]Indoor: 100 ~ 150 Meter[/align][*][align=left]Outdoor: 2000 ~ 14400 Meter (1.24~8.95 Mile, based on same unit on each end, in clear line of sight)[/align][/ul]
Old Mar 29, 2008 | 12:51 PM
droppedneon's Avatar
droppedneon
nope relay is new only thing i can think of is a wire is broken
Old Mar 29, 2008 | 02:59 PM
do a continuity test on the wires at the pcm to the relay... and then from the relay to the fan then to from the pcm to the fan...
