Friend needs help!
Old Mar 31, 2008 | 10:02 AM
johnMZ24's Avatar
johnMZ24
Default Friend needs help!
hey guys, this question is for my buddy, he has a 97 dodge neon with sohc and atx tranny, now, he put the jeep tb on.. when he did that it jumped up to 3000 from idle, so from what he told me he shut thecar off and put his old one back on and now it stays at 3 grand idling, but he also reset pcm, and changed iac.. what can it be?
Old Mar 31, 2008 | 10:12 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Friend needs help!
replace the TPS sensor with the one in the old TB if you can
Old Mar 31, 2008 | 10:27 AM
johnMZ24's Avatar
johnMZ24
kk i was gunna juss tell him to do that but he brought it to the dealer so hes gunna be payin alllllot....
Old Mar 31, 2008 | 12:41 PM
12 volt's Avatar
12 volt
You'll need to swap the larger tip on the Jeep IAC, over to the Neon IAC, and use the Neon IAC on the Jeep TB. If you dont air will leak cousing high idle
http://www.geocities.com/lover232/Enjoy.html
