check engine light is on
Old Apr 1, 2008 | 04:17 PM
rockenuptown's Avatar
rockenuptown
Default check engine light is on
does any one know where u can get the codes for the check engine light
Old Apr 1, 2008 | 05:38 PM
12 volt's Avatar
12 volt
Default RE: check engine light is on
Q: My Check Engine Light (CEL) is on, what do I do?
A: To read any codes on your neon, put the key in the ignition and cycle it to ACC on-off-on-off-on within 5 seconds. As the CEL flashes, count the number of flashes. This represents the code. An example would be flash-flash-flash-flash, pause, flash-flash-flash, which would be a Code 43, single or multiple cylinder misfire. A list of codes can be found HERE or HERE.
