r/t is acting funnny
Old Apr 1, 2008 | 12:11 AM
mulletman11's Avatar
mulletman11
Default r/t is acting funnny
ok
so my front motor mount was shot, torn through
so i bought a set of polyurathane ones from modern
and i installed all 3
now sometimes, i have SO MUCH WHEEL HOP, i freak out, i wanna drive the f%$#ing car off a cliff
wtf, arent motor mounts supposed to STOP wheel hop?
it usally only does it if its been driving all day, then i pak it and drive it again after sitting for about an hour
and when it rains
im stumped and frustrated
EDIT***********
also, when the rpms go beyond 3500
my heat kicks on full blast no matter what temp/pressure i have it set to
kinda cool this winter, but its getting hotter
and its not gonna be so cool anymore, pardon the literalness(sp?)
help....?
Old Apr 1, 2008 | 12:49 AM
95to96transplantneon's Avatar
Default RE: r/t is acting funnny
check your radiator support where it connects they have been known to tear apart around where the mm connects...
Old Apr 1, 2008 | 12:53 AM
mulletman11
that would cause SEVERE wheel hop?
there is, looks like an alumium bracket, connects bottom of engine to bottom of tranny, then goes up a little.
that piece has 4 bolts, there is a split in front of one of the bolts, but it still feels stable. complete seperation of this alumiun plate.
and the heat issue?
Old Apr 1, 2008 | 01:19 AM
It will cause massive wheel hop... ask me how i know...
Old Apr 1, 2008 | 01:21 AM
mulletman11
how do you know?
and what about my broken support?
and my heat blowing prob?
Old Apr 1, 2008 | 01:43 AM
no idea about the heater problem thats just weird...
i know becuase mine is cracked and really bad and my motor moves all over the place with my inserts in...
Old Apr 1, 2008 | 02:04 AM
mulletman11
you dont think the crack support is the issue?
i dont but wanna get ppls imput
and heat thing is really weird
its kinda cool
but weird
Old Apr 1, 2008 | 03:04 AM
no its an issue... you need to fix it...
this is how others have done it...
[IMG]local://upfiles/61619/95B44C73F7C54432AD26917D50F8D43A.jpg[/IMG]
Old Apr 1, 2008 | 03:15 AM
mulletman11
not what im talking about, il take in pic in the morning
the aluminium brace that connects from the bottom of the tranny to the bottom of the engine
that is split i dont know if my rad suport is
ill check in the light
Old Apr 1, 2008 | 08:54 AM
spudsterier's Avatar
spudsterier
your talking about the plate on the very bottom of the motor....looks almost like a skid plate...
2 bolts on the tranny and 2 bolts on the oil pan hold it on...
no, that shouldnt effect your wheel hop.....i took mine off long ago
