Apr 1, 2008 | 05:33 PM
Is it possible to blow the fuel pump by leaving your gas cap off accidentally? im just wondering cuz i filled up started my journy home and it all of a sudden shut off i check timeing belt. still there. wasnt overheating and had oil. i tried starting again and it fired right up. got home shut it off and started a few times. i go out about an hour later and the fuel pump wont click on anymore. the fuse isnt blown i just cant figure it out?[:@] any help would be great.
Reply 0
Apr 1, 2008 | 05:35 PM
RE: gas cap?
no
could be time for a new pump
EDIT orthe fuel pumpwiring/relay may be having issues
Reply 0
Apr 2, 2008 | 03:32 AM
RE: gas cap?
u can also try the relay befor buying a new pump its cost less pepo come into wrk trying to return used pumps after they find out it was a relay
Reply 0
Apr 2, 2008 | 09:14 AM
RE: gas cap?
check to see if ur getting power... try to see if u could hear it whine
Reply 0
Apr 2, 2008 | 10:42 AM
RE: gas cap?
no i cant hear it whine thats the problem. i checked the fuse and the relay and they are both good. could it be possible i knocked a wire loose on the pump itself. ive been going through some really deep snow lately. but when it quit on me i wasnt going through any snow at all. but the roads i also travel regularly are very very bumpy and rough do u think it could maybe be the wire on the pump?
Reply 0
Apr 2, 2008 | 04:20 PM
RE: gas cap?
what about the reset button in the trunk??
we live on dirt roads and it wasnt graded in awhile and a friend had a tempo and hit a lot of bumps and the engine cut off then someone sugested the reset and sure as **** it was triped
although you said you already had it parked its just a thought
Reply 0
Apr 2, 2008 | 06:33 PM
RE: gas cap?
Neons dont have a re-set button or trip for the fuel pump like the Fords.
Reply 0
Apr 3, 2008 | 11:02 AM
RE: gas cap?
is it possible the connector came off? from all the bumps on my gravel road?
Reply 0
Subscribe
