want some power our of a 96 sohc
Old 04-02-2008, 03:51 PM
das2123's Avatar
das2123
das2123 is offline
Default RE: want some power our of a 96 sohc
ORIGINAL: I_Ride_Neon
Whats better the 95 or the magnum cam?
Magnum cam is more agressive, the 01 in particular. But the 95 cam doesn't require a spring upgrade and is a cheap, nice upgrade.
Old 04-02-2008, 04:00 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
So if i grab a magnum valve i need to grab springs with it? Does the head swap?
Old 04-02-2008, 04:05 PM
das2123's Avatar
das2123
das2123 is offline
You really should. They are only about $50.
Does the head swap?
Yes it does. It doens't have an EGR port to my knowledge, so you would either have to drill holes for it or run a Mopar PCM.
Old 04-02-2008, 04:06 PM
I_Ride_Neon
I have my egr blocked off anyways?
I am turbod.
Old 04-02-2008, 05:51 PM
Neon_Freak's Avatar
Neon_Freak
Neon_Freak is offline
well when i get some money saved up ill do that
Old 04-02-2008, 05:56 PM
das2123's Avatar
das2123
das2123 is offline
I am turbod.
Then the mag head would be a nice compliment.
Old 04-03-2008, 01:26 PM
dtjackten's Avatar
dtjackten
dtjackten is offline
2nd gen neon peace keeper
yeah, i have an 02 and got a cheap first gen head, head it built well, and had to make a block off plate, what a difference.......
but the problem was once i felt the power i had to have more. a year later it was boosted
Old 04-03-2008, 01:50 PM
Neon_Freak's Avatar
Neon_Freak
how would the dodge magnum cam work on the sohc 2.0 ???? its a v-6
Old 04-03-2008, 01:52 PM
JackMehoffer69's Avatar
JackMehoffer69
JackMehoffer69 is offline
ORIGINAL: das2123
Why not just leave it off and take your check engine light out? if it runs like crap and something goes outhave autozone run the codes.
Old 04-03-2008, 03:08 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
ORIGINAL: Neon_Freak
Not the dodge magnum, but the 2.0 SOHC magnum engine in the 2nd gen neons.
Quick Reply: want some power our of a 96 sohc
