want some power our of a 96 sohc
Old Apr 1, 2008 | 11:56 PM
Neon_Freak's Avatar
Neon_Freak
Default want some power our of a 96 sohc
i have a 96 sohc neon 5 speed...all stock for now..i was wanting some more power out of it..besides the exhuast, and intake..what else could i do that would be cheap and get some ponies in the moter? thanks
Old Apr 2, 2008 | 12:00 AM
p8ntballa113's Avatar
p8ntballa113
Default RE: want some power our of a 96 sohc
Spark plugs and wires are supposed to give ya a few more hp.
Old Apr 2, 2008 | 01:55 AM
95to96transplantneon's Avatar
95 cam... its more agressive and good for another 5-6 hp...
I have one if you are interested for 50 bucks + shipping
Old Apr 2, 2008 | 02:26 AM
Neon_Freak's Avatar
Neon_Freak
how do i get rid of a code 12 and i did the d/c of the neg battery cable??? also
Old Apr 2, 2008 | 03:10 AM
vegas_neon's Avatar
vegas_neon
i put a 96 dohc computer it helped and when i had my atx computer it took off
Old Apr 2, 2008 | 03:33 AM
ryleynoyes's Avatar
ryleynoyes
code 12 is almost always on there, it's from battery voltage dropping too low within the last 50 starts (basically, when you start the car, the starter draws the power below that level)
it's technically for power to pcm disconnected within last 50 starts, but from what i've heard is it's just a voltage monitor pretty much
Old Apr 2, 2008 | 01:39 PM
Neon_Freak's Avatar
Neon_Freak
o ok so will it ever clear then???
Old Apr 2, 2008 | 03:19 PM
das2123's Avatar
das2123
ORIGINAL: p8ntballa113
No they don't!
ORIGINAL: Neon_Freak
After you turn the ignition on and off 50 times without disconnecting the battery.
Old Apr 2, 2008 | 03:23 PM
das2123's Avatar
das2123
The 00-05 magnum cam is a nice upgrade for the 1st gen neon. Get the springs as well....put that with a nice ported/polished head and you can feel a nice difference.
Old Apr 2, 2008 | 03:49 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Whats better the 95 or the magnum cam?
