car burning oil
Old Apr 2, 2008 | 08:49 AM
rockenuptown's Avatar
rockenuptown
Default car burning oil
my car is burning alot of oil but heres the thang i put some high *** oil like sae 60 and its not burning this oil but smokes still coming out and its coming out where the dipstick is to i think that to much and it dnt run %100
Old Apr 2, 2008 | 12:15 PM
12 volt's Avatar
12 volt
Default RE: car burning oil
your not getting porper lube with that thick stuff,so some componets in you engine are getting really hot. the highest i would run would be a 10w 40.
just changing your oil isnt going to fixtheproblem you have to find your internal leak. whether its piston rings, valve guides or or a blown HG
Old Apr 2, 2008 | 01:18 PM
rockenuptown
u sure cause i ran 10W 40 before it still burned off this stuff anit it seems find
Old Apr 2, 2008 | 01:27 PM
12 volt's Avatar
12 volt
i dont know of any oil that can stop your leak, i was just saying thats the highest viscosity that i would ever consider putting in my engine.
your engine has internal issues your not going to be able to fix it by swiching viscosity
http://www.newcarbuyingguide.com/ind...840/event=view
Old Apr 2, 2008 | 01:36 PM
rockenuptown
yea but i mean i drive it on a road track so im agressive at the wheel thats y i put so high *** oil in it cause its going to get hot it might be time for a new rebuild kit its been 50,000 miles since i replaced anything its a new dropped engine i got that motha ****er up to 255bph on a sohc all motor haha runs at 7800 rpm i run the hell out of it so i guess im just going to get a rebuild kit
Old Apr 2, 2008 | 01:40 PM
12 volt's Avatar
12 volt
thats why, 60 is way too heavy. You were stavring the enigne of oil.
i would just get a new engine
Old Apr 2, 2008 | 01:42 PM
rockenuptown
or i can just get so new oil and a rebuild kit
Old Apr 2, 2008 | 01:43 PM
rockenuptown
but i c where u coming from i probly drop down to a 10w 40
Old Apr 2, 2008 | 09:39 PM
outlawrebel's Avatar
outlawrebel
i would like to know what else i can do... i have changed the oil and put a new oil pan gasket on it. mine is a 98 neon. i just brought it.but it's not a really bad leak about a 1/2 qt every 4 or 5 days. is there anything thing that i can do because i travel alot for my job. i have 5-30 syn blend in it right now.
Old Apr 2, 2008 | 09:42 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
mine used to do a half a quart per tank. didnt smoke didnt leak so i said screw it just left it as it was and never had any issues with it
