LOOSING COOLANT!
Old 04-04-2008, 01:16 PM
12 volt's Avatar
12 volt
12 volt is offline
Default RE: LOOSING COOLANT!
running without a thermostat is going to increase the wear on your engine. Need more info to effectively troubleshoot
does it over heat?
how long does it take to over heat?
does it happen when your at stop lights?
does the coolant bubble in the resivor?
Old 04-04-2008, 05:13 PM
neonracer1010's Avatar
neonracer1010
neonracer1010 is offline
the thermostat was sticking shut i took it out and it runs perfectly fine til i can get a new one.
and im pretty sure it was coming out of the coolant tank so its all good now.
how can running w/out t stat hurt motor???
Old 04-05-2008, 03:13 PM
bone33's Avatar
bone33
bone33 is offline
ORIGINAL: neonracer1010
because it takes way too long for it to come up to proper operating temp. lubrication will suffer due to lack of heat in the block for a much longer duration.
Quick Reply: LOOSING COOLANT!
