LOOSING COOLANT!
Apr 2, 2008 | 10:34 AM
LOOSING COOLANT!
i am loosing coolant from somewhere! and i have no idea where it could be coming from??? and its not the radiator i think its in the back of the engine bay somewhere. i noticed when i got to school this moring
Apr 2, 2008 | 12:09 PM
RE: LOOSING COOLANT!
check all your hoses, even the smallest leakcan loose all you coolant. heater lines are closer to the back of the engine, just hope its not a blown HG.
Apr 2, 2008 | 06:37 PM
i just changed hg so id be pissed if it was and its on the passenger side somewhere?
also how hard would it be to wire the fans so there on a switch
Apr 2, 2008 | 07:24 PM
see if its ur pump it will leak down the block
Apr 3, 2008 | 03:27 AM
Quote:
ORIGINAL: neonracer1010
wouldn't happen to havebeen the same spot you lost your education? would it? I think I'm
losing it.
Apr 3, 2008 | 07:56 AM
DICK! lol i was in a hurry when i typed that i did it at school and had to finish typing it while the teacher was gone!
Apr 3, 2008 | 09:23 PM
iwas just busting your chops dont take it personal
im not a grammar ***** just I like to point out the difference between lose and loose.
Apr 4, 2008 | 08:16 AM
way to offer help jackmeoffwhatever
put dye in your coolant and see where the colors go
Apr 4, 2008 | 09:58 AM
maybe you thermostat didnt open or the coolant was over full and it just came out the over flow tank
Apr 4, 2008 | 10:38 AM
yup took the thermostat out and its fine now haha
running without t stat its fine takes a while to heat up but its fine
