what year ford or exclipse has compatable bigger fuel injectors with the Neon?
Old Apr 7, 2008 | 08:52 AM
das2123's Avatar
das2123
Default RE: what year ford or exclipse has compatable bigger fuel injectors with the Neon?
ORIGINAL: JackMehoffer69
ORIGINAL: das2123
You can use 05 and up injectors from a Mustang GT which has the 4.7L engine in it, not the 5.0! They swap right in because they use the EV6 connector. You can unplug your stock neon injectors and pop in the stock Mustang GT 24 lb. injectors.
05 and up? thats quite new, the junk yard by me doesn't have anything quite that new. darn. good information none the less.
You probably won't find them in a junkyard, but go on a Mustang forum and buy some used ones from the guys who upgrade.
Old Apr 8, 2008 | 06:10 AM
HankL's Avatar
HankL
volunteers put together this table:
http://users.erols.com/srweiss/tableifc.htm
