HELP! Brakes. ASAP Please.
Old Apr 5, 2008 | 09:49 PM
chenzo's Avatar
chenzo
Default HELP! Brakes. ASAP Please.
Ok. so im in iowa, visiting some friends. on the drive out here, it would seem like the passenger side brake would be stuck, then after a bit it would let go and everything would be fine. Today, we drove to a neighboring town, and it was noticable that it was sticking. i could tell from acceleration, i could tell from shifting, i could tell from the fact that myt car wouldnt coast more than twenty feet without coming to a halt. so we went back, and got my buddies neon.
so i just got home, took it out to see if it was still sticking, and everything was fine. i can get a new caliper for 34 bux, and have it in in less than an hour. IS THAT THE PROBLEM? does that sound like what the problem is? it has been doing the on off sticking thing for about 2 weeks now, and when i stop afte it is sticking, i can obviously smell the brakes burning. and it only seems to be coming from the passenger side.
HELP. please. i leave for home tomorrow, and i want to change it if you think its the caliper, like i do. THANKS!!!
Old Apr 5, 2008 | 10:06 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: HELP! Brakes. ASAP Please.
sounds like the caliper.
Old Apr 5, 2008 | 10:13 PM
bone33's Avatar
bone33
caliper
Old Apr 5, 2008 | 10:16 PM
chenzo's Avatar
chenzo
ok. well, im definately gonna get up and change it before i drive the 200 miles home. thanks guys.
Old Apr 5, 2008 | 10:17 PM
12 volt's Avatar
12 volt
check for leaks
you could also try flushing the barke system
Old Apr 5, 2008 | 10:37 PM
neoncrazy101
ORIGINAL: 12 volt
check for leaks
well technically he shouldn't even have a tree in his brake system
Old Apr 6, 2008 | 02:30 AM
12 volt's Avatar
12 volt
yes technically but id rather look at the cheaper fixes first before i start buying parts
