Is 9:47 a good 1/8th mile time ?
Old Apr 7, 2008 | 08:21 AM
uta_flyinghigh's Avatar
uta_flyinghigh
Default Is 9:47 a good 1/8th mile time ?
As the title says. I have no other Neon here to benchmark mine so I'll go with your opinion.
UTA
Old Apr 7, 2008 | 08:31 AM
mulletman11's Avatar
mulletman11
Default RE: Is 9:47 a good 1/8th mile time ?
i have no idea how to figure that out
do you have 0-60 ft time?
maybe
Old Apr 7, 2008 | 11:23 AM
cuwa's Avatar
cuwa
Its kinda slow. do you have the SOHC or DOHC? I ran a 15.19 in 1/4 mile in a DOHC w/ cold air intake and a cat-back.
Old Apr 7, 2008 | 11:35 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Should just go dohc and be done with it You have a 1.6L yes? That is about a 18.xx 1/4 which are atx times. Slow. Without your mods, you should be knocking into 15's with all the weight loss. Remedy? Boost, or a dohc head pistons. Check to see if the block is the same first. not sure about the 1.6L block.
