want to buy rear sway bar mounts
as title says, i want to buy the mounting brackets for the rear sway bar
i tried to order some from mopar (dodge) dealership thing, but they said dodge no longer has them, discontinued (bastards...)
so please, help a neon freak out!
http://www.neongoodies.com/Goodies/S...Hardware.shtml
i think there's anouther place, but i cant remember
nope, not those ones, the ones that mount to the bottom of the car (i already have the neon goodies ones on the way, btw!)
so i still need the stock under car ones
sell me a set, and i might be able to fab up some new ones, as i'm going to school for machining
Trending Topics
ORIGINAL: spudsterier
i have a set....but im not sure if i have the bushings
and mullet.... are you serious? your r/t SHOULD have a rear sway bar from the factory... unless it's 95/96, it might not,but i think even those had rear swaybars
real easy to find out, go to your car, look under the *** end, and if you see a bar going under the spare tire hump, all the way from one strut to the other, that has some wierd bends in it, you have a rear sway bar
something like this!
http://www.modernperformance.com/pro...oducts_id=1401
in fact, this is what i have
too bad i didn't see it earlier, but another brand (can't recall the name, not eibach tho) has what appears to be the brackets in the set, and they are the same size and cheaper than the suspension techniques (i posted on it a week ago or less)
