Manual Transmission
Old Apr 7, 2008 | 09:36 PM
DNeon's Avatar
DNeon
Default Manual Transmission
Hey guys
I'm lookin for a good manual tranmission that would compliment the 2.4 Turbo. Or should I stay with the stock MTX. I'm aiming at anywhere between 250-500 hp not sure yet lol.So I'm lookin for maybe different gear ratios that would help the turbo.Any input at all would help me a ton
Thanx =]
Old Apr 7, 2008 | 11:40 PM
95to96transplantneon's Avatar
Default RE: Manual Transmission
use the sohc tranny if you want your turbo to spool quick and have massive power quick... ideal for hybrids or anything bigger then a t3
use the rt tranny if you want to have longer gears and stay in gear longer... ideal srt-4 turbofold
there is a another tranny that would be best... however its on the export models... 4.12 final gear ratio
Old Apr 7, 2008 | 11:43 PM
mulletman11's Avatar
mulletman11
ok
built turbo motor v built turbo motor
sohc or dohc?
pros/cons....
Old Apr 8, 2008 | 12:05 AM
when you start talking boost...
I honestly dont think it matters... unless your talking the most ultimate of the ultimate... I mean there is a 404hp sohc turbo neon around... and thats the most I personally have heard of... you can get the dohc much much higher... like 650 range... but if you want the real deal and have tons of *** loads of money... get ahold of dcr and have him build you a punched out stroked 2.6... and turbo that bitch...
Old Apr 8, 2008 | 12:48 AM
DNeon's Avatar
DNeon
ORIGINAL: 95to96transplantneon
wat do you mean ideal SRT Turbofold? it works better with it? if yes then how come? and wat export model are you talkin about?
Thanx for all the info =]
Old Apr 8, 2008 | 12:52 AM
DNeon's Avatar
DNeon
built turbo motor vs built turbo motor? I dont get wat you're sayin
Old Apr 8, 2008 | 01:14 AM
the neon was exported else where
some came with a 1.8 sohc and some came with a 2.0
but there 2.0 had a really tall 4.12 final drive ratio...
Old Apr 9, 2008 | 09:53 PM
Ghost Neon 2's Avatar
Ghost Neon 2
best trans for a turbo engine is the turbo PT trans. Period.
Higher torque rating and has a 3.26FD. This is what the srt guys upgrading to.
Old Apr 9, 2008 | 09:56 PM
das2123's Avatar
das2123
^^^ Are there any fitment issues with the PT trans?
Old Apr 9, 2008 | 10:46 PM
mulletman11
ORIGINAL: DNeon
2 fully build turbod motors ones a sohc ones a dohc, pros and cons of them
thats what i was asking
