Can't remove ignition key
Old Apr 17, 2008 | 02:32 PM
ryleynoyes's Avatar
ryleynoyes
Default RE: Can't remove ignition key
ORIGINAL: DOHCgarrett t3
thats whats great about Alaska. it never gets dark in the summer. and the winter we get about 6 hours of daylight. but who the hell wants to work on their car in the winter anyways
at least outside anyway, haha, inside the daylight doesn't matter anyway! you know what i'm talking about, right? mr. hurricane?
Old Apr 17, 2008 | 03:25 PM
Jr. Mechanic's Avatar
Jr. Mechanic
When this happens, try pushing the shift lever forward as hard as you can without breaking it, and see if the key comes out.
Old Apr 17, 2008 | 11:12 PM
stodd4's Avatar
stodd4
Worked on it today and finally identified the problem. It was not the cable as I thought. It was a gumbed up return spring in the shifter tube. It wouldn't let the release button on the shifter reset, which wouldn't allow it to push down some kind of plastic release lever, which in turn pulled the cable that released the key. Man............all that and a fix with a squirt of carb cleaner and lube. At least it didn't cost me any money, only aggrivation.
Old Apr 18, 2008 | 08:34 AM
das2123's Avatar
das2123
^^^Best kind of fix! FREE!
