any strong radiators out there that are cheap.. JEREMY HELP
Old Apr 18, 2008 | 03:24 AM
boxerjl2's Avatar
boxerjl2
Default any strong radiators out there that are cheap.. JEREMY HELP
so i dont want to go to the Jy and just get a used radiator and end up with it haveing a hole in it... so i was curious if i should just get the OEM replacement radiator or if there is a better one somewere out there im looking to spend around $100 which ive found one for $111 shipped at radiator.com.. so what do you guys think??
Old Apr 18, 2008 | 03:26 AM
boxerjl2's Avatar
boxerjl2
Default RE: any strong radiators out there that are cheap
http://cgi.ebay.com/ebaymotors/95-99...spagenameZWDVW
that one is pretty cheap...
Old Apr 18, 2008 | 07:47 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Call 1-800-radiator
They have one for $99.
Old Apr 18, 2008 | 08:46 AM
das2123's Avatar
das2123
The ebay one should work fine.
Old Apr 18, 2008 | 02:34 PM
95to96transplantneon's Avatar
I'm a very stong advicate of the 1980 vw rabbit radiator... as seen here...
http://cgi.ebay.com/ebaymotors/RADIA...spagenameZWD1V
it has 2 rows for better cooling and it gives you **** tons more room as seen here...
Old Apr 18, 2008 | 03:01 PM
das2123's Avatar
das2123
^^^Where are the fans?
Old Apr 18, 2008 | 03:14 PM
Jr. Mechanic
Thats exactly what I was wondering...
Old Apr 18, 2008 | 03:38 PM
das2123's Avatar
das2123
Can't use that radiator down in the south. No fans is a no-no! Plus, I don't like the zip tie way of doing things.
Old Apr 18, 2008 | 04:18 PM
The car has fans now but the pic was just to show how much more room you could have... there are no zip tie's either... he made brackets for it...
on a side note... I run without fans and im fine... but then again i live in montana
Old Apr 19, 2008 | 08:39 PM
das2123's Avatar
das2123
I thought Uptown wasnt running fans due to living in Minnesota though?
