Code P1404 ?
Old Apr 19, 2008 | 06:53 PM
l33tn3wb3r's Avatar
l33tn3wb3r
Default Code P1404 ?
P1404
IAT - B Circuit Malfunction/ Exhaust Gas Recirculation
Closed Position Performance
English please anyone?
My car's first service engine light brought me to this.
Old Apr 19, 2008 | 09:06 PM
das2123's Avatar
das2123
Default RE: Code P1404 ?
There is no error code P1404 for the neon that I know of.
Did you try the key dance to pull the code?
To read any codes on your neon, put the key in the ignition and cycle it to ACC on-off-on-off-on within 5 seconds. As the CEL flashes, count the number of flashes. This represents the code. An example would be flash-flash-flash-flash, pause, flash-flash-flash, which would be a Code 43, single or multiple cylinder misfire. A list of codes can be found HERE or HERE.
Old Apr 19, 2008 | 11:28 PM
95to96transplantneon's Avatar
he is right das heres the list of codes...
1995
11
No Crankshaft Reference Signal At PCM
P1390 Timing Belt Skipped Tooth
P1391 Intermittent Loss Of CMP Or CKP
12
Battery Disconnected
13
P1297 No Change In MAP From Start To Run
14
P0107 MAP Sensor Voltage Low
P0108 MAP Sensor Voltage High
15
P0500 No Vehicle Speed Sensor Signal
16
Knock Sensor Circuit
17
P0125 Closed Loop Temperature Not Reached
21
P0131 Upstream O2 Sensor Voltage Shorted To Ground
P0132 Upstream O2 Sensor Shorted To Voltage
P0133 Upstream O2 Sensor Slow Response
P0134 Upstream O2 Sensor Stays At Center
P0135 Upstream O2 Sensor Heater Failure
P0137 Downstream O2 Sensor Voltage Shorted To Ground
P0138 Downstream O2 Sensor Shorted To Voltage
P0139 Downstream O2 Sensor Slow Response
P0140 Downstream O2 Sensor Stays On At Center
P0141 Downstream O2 Sensor Heater Failure
22
P0117 ECT Sensor Voltage Low
P0118 ECT Sensor Voltage High
23
P0112 IAT Sensor Low
P0113 IAT Sensor High
24
P0121 TP Sensor Voltage Does Not Agree With MAP
P0122 TP Sensor Voltage Low
P0123 TP Sensor Voltage High
25
P0505 IAC Motor Circuits
27
P0201 Injector No. 1 Control Circuit
P0202 Injector No. 2 Control Circuit
P0203 Injector No. 3 Control Circuit
P0204 Injector No. 4 Control Circuit
31
P0443 EVAP Solenoid Circuit
P0441 EVAP Purge Flow Monitor Failure
32
P0401 EGR Solenoid Circuit
P0403 EGR System Failure
33
A/C Clutch Relay Circuit
34
Speed Control Solenoid Circuit
35
P1491 Fan Control Relay Circuit
37
P1899 P/N Switch Failure
P0740 Torque Converter Clutch, No RPM Drop At Lockup
P0743 Torque Converter Clutch Solenoid Circuit
41
Generator Field Not Switching Properly
42
Fuel Pump Relay Control Circuit
43
P0300 Multiple Cylinder Misfire
P0301 Misfire Cylinder No. 1
P0302 Misfire Cylinder No. 2
P0303 Misfire Cylinder No. 3
P0304 Misfire Cylinder No. 4
P0351 Ignition Coil No. 1 Primary Circuit
P0352 Ignition Coil No. 2 Primary Circuit
44
Battery Temperature Sensor Volts Out Of Limit
46
Charging System Voltage Too High
47
Charging System Voltage Too Low
51
P0171 Fuel System Lean
52
P0172 Fuel System Rich
53
P0601 Internal Controller Failure
54
P0340 No Cam Signal At PCM
55
DTC Fault Display Complete
62
PCM Failure SRI Mile Not Stored
63
PCM Failure EEPROM Write Denied
64
P0420 Catalytic Converter Efficiency Failure
65
P0551 Power Steering Switch Failure
P0703 Brake Switch Sense Circuit
71
P1496 5 Volt Supply Output Too Low
77
Speed Control Power Circuit
1996-99
11
P0320 No Crankshaft Reference Signal At PCM
P1398 Misfire Adaptive Numerator At Limit
12
13
14
P0107 MAP Sensor Voltage Too Low
P0108 MAP Sensor Voltage Too High
15
P0500 No VSS Signal
16
P0325 Knock Sensor Circuit
17
P1281 Engine Cold Too Long
21
P0131 Upstream O2S Shorted To Ground
P0132 Upstream O2S Shorted To Voltage
P0133 Upstream O2S Slow Response
P0134 Upstream O2S Stays At Center
P0135 Upstream O2S Heater Failure
P0137 Downstream O2S Shorted To Ground
P0138 Downstream O2S Shorted To Voltage
P0140 Downstream O2S Stays At Center
P0141 Downstream O2S Heater Failure
22
P0117 ECT Sensor Voltage Too Low
P0118 ECT Sensor Voltage Too High
23
P0112 IAT Sensor Voltage Low
P0113 IAT Sensor Voltage High
24
P0121 TP Sensor Signal Does Not Agree With MAP
25
P1294 Target Idle Not Reached (+/-200 RPM)
P1299 Vacuum Leak Found (IAC Fully Seated)
27
P0201 Injector Circuit No. 1
P0202 Injector Circuit No. 2
P0203 Injector Circuit No. 3
P0204 Injector Circuit No. 4
31
P0442 EVAP Monitor Small Leak Detected
P0443 EVAP Purge Solenoid Circuit
P0455 EVAP Monitor Large Leak
P1486 EVAP Monitor Pinched Hose Found
P1494 Leak Detection Pump Switch Or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit
32
P0401 EGR System Failure
P0403 EGR Solenoid Circuit
33
P0645 A/C Clutch Relay Circuit
34
P1595 Speed Control Solenoid Circuit
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
35
P1491 Radiator Fan Control Relay Circuit
37
P0740 TCC No RPM Drop At Lockup
P0743 TCC Solenoid Circuits
P1899 P/N Switch Stuck In Park or Gear
41
P0622 Generator Field Improper Switching
42
P1282 Fuel Pump Relay Control Circuit
P1388 ASD Relay Control Circuit
P1389 No ASD Relay Output Voltage At PCM
P0460 Fuel Level Sending Unit & Circuit, No Change Over Miles
P0462 Fuel Level Sending Unit Voltage Out Of Limits, Too Low
P0463 Fuel Level Sending Unit Voltage Out Of Limits, Too High
43
44
P1492 Ambient/Battery Temperature Sensor Voltage High
P1493 Ambient/Battery Temperature Sensor Voltage Low
46
P1594 Charging System Voltage Too High
47
P1682 Charging System Voltage Too Low
51
52
53
P0600 PCM Failure SPI Communications
54
55
61
P0106 Barometric Pressure Out Of Range
62
P1697 PCM Failure SRI Mile Not Stored
63
P1696 PCM Failure EEPROM Write Denied
65
P0551 PS Pressure Switch Failure
P0703 Brake Switch Stuck, Pressed, Or Released
71
P1496 5 Volts Output From Regulator Low
72
P0420 Catalyst Efficiency Below Required Level
77
P1683 Speed Control Power Relay Circuit
Old Apr 20, 2008 | 04:26 PM
das2123's Avatar
das2123
ORIGINAL: 95to96transplantneon
So where is P1404 then?
Old Apr 22, 2008 | 07:38 PM
thedark69's Avatar
thedark69
look for a EGR Valve problem like if you got The 5Volt form the ECM and a good ground, it may be a sensor too, or the valve itself
