egr removal
Pros: cleaner intake manifold and TB
Cons: damaging to the environment
You won't gain any HP or any other type of gain from doing this. If you don't have an aftermarket PCM then you will get code for the EGR valve.
ORIGINAL: thedark69
When your car need power the EGR Valve is closed. when you are in the streets and go slowly your EGR keep your engine cooler and get lower NOx emission
The EGR system will not function while at idle.
