something wrong with tranny
Old Apr 20, 2008 | 05:30 PM
  #21
Neon_Freak's Avatar
Neon_Freak
Default RE: something wrong with tranny
C:\Documents and Settings\J & L OUTLET\My Documents\MVC-008E.JPG
Old Apr 20, 2008 | 06:34 PM
  #22
Neon_Freak's Avatar
Neon_Freak
anyone know??? if i do change the fluid will that help any???? thats the pic of the passenger side cv axle where something rubbed on it
Old Apr 20, 2008 | 08:47 PM
  #23
12 volt's Avatar
12 volt
that not how you post a pic.
this link expains how
https://dodgeforum.com/m_584032/tm.htm
Old Apr 20, 2008 | 09:02 PM
  #24
Neon_Freak's Avatar
Neon_Freak
here is the pics the top one is the passenger side. bottom driver
[IMG]local://upfiles/87349/65CE0BD78CA84251810F0CBA2462F78C.jpg[/IMG]
[IMG]local://upfiles/87349/069247ED0AAD412CA66ECDF90CCAA165.jpg[/IMG]
Old Apr 20, 2008 | 10:54 PM
  #25
95to96transplantneon's Avatar
you can always take the inspection plate off and see if a piece of clutch is flying around in there... there is a ring that goes on the clutch line where it connects to the fork and some times it falls off the line and drops to the bottom of the bellhouseing... but the scraping on your axel is perplexing... maybe you drove over something and it got stuck thats odd... I would still check the tranny oil and inspection plate... I would use atf+4 just for the reason of its red... you will be able to see any debris in it that may be there if you come across any more problems... just drain it in one of your wifes good white casorole dishes and check for debris then get a good hand pump and pump it back in if it looks good... you can re-use it if it looks good... the orig. tranny fluid was ment to last the life of your car...
Old Apr 21, 2008 | 01:01 AM
  #26
Neon_Freak's Avatar
Neon_Freak
ok ill do that in the morning.. i have mecron lllor whatever tranny oil wil that work?
Old Apr 21, 2008 | 03:49 AM
  #27
Neon_Freak's Avatar
Neon_Freak
ok well i took all the bolts out to get the inspection plate out and all i could do was swivel it back and forth it wouldnt come down..but didnt look like anything was loose inside..so i just but it all back together...
Old Apr 21, 2008 | 05:55 PM
  #28
Neon_Freak's Avatar
Neon_Freak
i tried again today i still cant take it off the car. but didnt look like anything was loose inthere so i just wont mess i with it any more..
Old Apr 21, 2008 | 07:09 PM
  #29
Jr. Mechanic's Avatar
Jr. Mechanic
Well... Dont look any father than that CV joint... That is obviously your clunking problem...
